Upgrade to Premium
Reply
  #1
Old 07-31-2017, 09:36 AM
UPsnowbiker UPsnowbiker is offline
Currently: Not set.
UPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond repute
Default Lectron on a 450 XCW
Opinions please
I'm in UP of Michigan and have a 2010 450 XCW. I just had the top end done and the bike is set up well for my use as a snowbike and dualsport and I would like to keep it for a few more years if possible. I have a 300xc now for woods that will take a lot of wear away from it.
Besides a lectron for the winter I'm interested in it for trips to mountain elevations as well.
It costs about $750.
Does this seem like a worthy purchase if I want to run this bike for a few more years.
I know 300 owners swear by them but I haven't heard too much about 4 strokes.
Thanks
Rate this post: Yes | No
  #2
Old 07-31-2017, 03:02 PM
yooper01 yooper01 is offline
Currently: Wheel mode
yooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond reputeyooper01 has a reputation beyond repute
Default
I know a guy who knows a guy who talked to a guy who said lectron on 4 strokes work good.
Sent from my XT1650 using Tapatalk
  #3
Old 07-31-2017, 03:43 PM
Currently: Not set.
Default
Sorry...forgot to clarify....all opinions welcome except for yours!
  #4
Old 08-02-2017, 08:53 AM
Tride Tride is offline
Currently: Not set.
Tride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond reputeTride has a reputation beyond repute
Default
No accelerator pump, I believe. I'd call Lectron. What don't you like about the Keihen?
  #5
Old 08-02-2017, 03:15 PM
Currently: Not set.
Default
Quote:
I don't like rejetting for the cold and altitude.
  #6
Old 08-02-2017, 06:43 PM
Default
Higher idle rpm of 2200ish keeps the Venturi up and compensated for the lack of pump.
  #7
Old 08-02-2017, 07:46 PM
Kx500tslt Kx500tslt is online now
Currently: Not set.
Basic Member
Kx500tslt is an unknown quantity at this point
Default Kx500 Lectron
All I can tell you is I like mine. I have a 40mm on my kx500 and it performed awesome for me. I was running a little rich back here in Minnesota and when I went out to west Yellowstone rejected a half turn leaner and it ran awesome! Never touched it the whole trip. It seemed a little complicated at first especially going from a stock carb. But now I view it as simplier. I encourage you to give Them a call. +1 (830) 331-2235 They have always been more than happy to field any questions I had, hope this helps.
  #8
Old 08-03-2017, 07:29 PM
Currently: Not set.
Default
Quote:
2T vs 4T is a whole different kettle of fish. Maybe the high idle makes the difference, but non-AC Pump 4ts suck.
  #9
Old 08-08-2017, 05:24 PM
CATSLEDMAN1 CATSLEDMAN1 is offline
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
Default 4 stroke LECTRON
I ran a 40mm LECTRON on my 04 WR450 YAMAHA. I have been a Lectron fan for 30k plus years so I had to give it a try.
When I ordered the carb from Lectron ( the only way to go price wise ) they had just finished a new Lectron Carb model just for 4 stroke singles.
The difference in the 4 stroke model is a separate air mixture adjuster for idle to low mid range so you can run a really clean throttle responsive low end.
Worked far better, throttle response wise, than my worked over bigger accelerator pump three or four needle KEIHIN.
Do you need an accelerator pump for a four stroke carb to work well ? obviously not, the lectron gave me really far better tight trees, jump up the bank, linear power closer to my fuelie bike than the Keihin did.
On my two strokes the Lectron was far more fuel efficient than a well tune KEIHIN. On the 4 stroke, not a big difference in fuel consumption, better, but not $500 better.
When I moved on to a FI KTM, I put the WR back into a dual sport type of bike for resale. WOW, after 4 years of dick'n with the WR cams/lcarb/ignition it was just to hot throttle response wise for pavement or dirt. To make a deal with the buyer , I reinstalled the stock KEIHIN and that mellowed out the bike. I didn't realize on the snow how much snotty'er I had made the old WR450.
Sold the 4 stroke LECTRON on Ebay for $400 first day. Cost $500 new if I recall.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to CATSLEDMAN1 For This Useful Post:
UPsnowbiker (08-10-2017)
  #10
Old 08-15-2017, 06:06 PM
smjdoo smjdoo is offline
Currently: Not set.
Basic Member
smjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant futuresmjdoo has a brilliant future
The Following User Says Thank You to smjdoo For This Useful Post:
UPsnowbiker (08-21-2017)
  #11
Old 08-18-2017, 12:25 PM
madmax's Avatar
madmax madmax is online now
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Click Here to Register
  #12
Old 08-18-2017, 12:28 PM
Lachoneus Lachoneus is online now
Currently: Not set.
Lachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond reputeLachoneus has a reputation beyond repute
  #13
Old 08-21-2017, 02:19 PM
Currently: Not set.
  #14
Old 08-29-2017, 03:24 PM
Murph's Avatar
Murph Murph is online now
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
The Following User Says Thank You to Murph For This Useful Post:
UPsnowbiker (08-31-2017)
  #15
Old 08-29-2017, 09:50 PM
portgrinder portgrinder is offline
Currently: Not set.
portgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond repute
The Following User Says Thank You to portgrinder For This Useful Post:
Sheetmetalfab (08-30-2017)
  #16
Old 08-30-2017, 12:16 AM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: ARO or AXYS or ARO or AXYS or ARO or AXYS or ARO or AXYS or ARO or AXYS
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
The Following User Says Thank You to Sheetmetalfab For This Useful Post:
  #17
Old 09-03-2017, 06:43 PM
jaredXwoodsman jaredXwoodsman is offline
Currently: Not set.
jaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant future
The Following User Says Thank You to jaredXwoodsman For This Useful Post:
UPsnowbiker (09-05-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 450 xcw and mountain horse ST Thread Starter — Barry Forum — Snow bikes Replies — 4 Last Post — 03-16-2017 04:05 PM
Thread — 450 xcw and Mountain horse Thread Starter — Barry Forum — Snow bikes Replies — 2 Last Post — 03-15-2017 09:26 AM
Thread — Timbersled fit kits (Used) in Canada. KX 450, Sxf 450, XCW 300, Cr 500 Thread Starter — Throndson Forum — Snowbikes & Parts (Swapmeet) Replies — 0 Last Post — 11-10-2016 01:34 PM
Thread — 2016 KTM 450 SX vs XCF XCW or 500 Thread Starter — ikold Forum — Snow bikes Replies — 9 Last Post — 11-17-2015 02:37 PM
Thread — 2013 KTM 450 XCW Thread Starter — Leftys Forum — ATV/Motorcycle (Swapmeet) Replies — 1 Last Post — 09-05-2013 12:32 PM
