What is going on with my 11 assault?
M
Aug 30, 2014
NW MT
Sled was dry on the mag side cylinder so I bought new injectors. Still have the problem. Swapped injectors around, put pto side in mad side and vise versa still have the problem. New plugs, I cut the spark plug wires thinking there may be a bad connection. Still not working. Checked fuel pump, seems good. Has spark. What else could be going on? I'm about to send it off a cliff and call insurance
richracer1
3,626
2,480
Idaho Falls, ID
Could be an electrical issue, start checking the wiring and connectors that go to the injectors themselves. Sounds like the mag injector isn't getting the signal to cycle from the ECU.
R
Dec 3, 2001
2,056
231
CO
Had similar problem took electrical contact cleaner to plug work s now
Sent from my XT1585 using Tapatalk
To clarify, which plug? Any specific one?
May be dealing with similar issues on an 11, have Blue injectors. But, if I can do something simple/free first, I'll try.
gtwitch
394
201
Laramie, Wyoming
Had a similar problem with my 11 PRO 800 and turned out to be the connector on the mag side injector and could not get one from polaris so very carefully disected it and repaired it by soldering the wires inside the connecter and re insulating it and rode the last half of the season with my repairs and still going, I think this was a MY-11 issue because they changed the injector harness in MY-12 Look up the pn's.
gtwitch in wyoming
Reg2view
2,392
1,600
Got my 11 injector harness replace after one year under warranty. Found the mag side issue before it rubbed through, but dealer stood up for me - poo wouldn't fix if it didn't rub through. They kinda $uck. No one mentioned fuel rail - is the injector getting fuel?
