Upgrade to Premium
Reply
  #1
Old 09-13-2017, 10:11 AM
CO 2.0's Avatar
CO 2.0 CO 2.0 is offline
Currently: Needs to snow
CO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond repute
Default Speedwerx handlebar setup on the 18
Install is really easy on the 18. The plug is right there next to the coolant bottle. I took a pic of what wires went to what plugs on the column switches before I disconnected them to put the plugs through the plastic. Not sure if orientation of the wire colors matter or not, but didn't want to take any chances. The 3/4" drill bit is best. .8" like the instructions say seems like it would be too big after deburring the edges. I used plenty of zip ties. Then moved the handlebars to full lock a bunch both ways to make sure none of the wires caught and had free movement. I mounted the reverse switch to where I can still hit it with my thumb while holding down the brake lever. The quality of the wiring harness is very good. Best I've seen for aftermarket quality on a sled. I spliced in my tether wires near the kill switch again like I did stock. Didn't want to have more wires going down the steering column down under the console.
__________________
'18 Mountain Cat 153, '16 Axys 3" PC 153 Silber
http://www.weknowsnow.com
5 out of 5 members found this post helpful. Rate this post: Yes | No
The Following 9 Users Say Thank You to CO 2.0 For This Useful Post:
bkm20x (09-13-2017), bradburck (09-13-2017), Chewy22 (09-13-2017), cpa (09-13-2017), DDECKER (09-13-2017), jakey-boy (09-13-2017), jeffheart153 (09-13-2017), ndfb35 (09-13-2017), summ8rmk (09-13-2017)
  #2
Old 09-13-2017, 07:32 PM
nh_sled_head nh_sled_head is offline
Currently: Not set.
Basic Member
nh_sled_head is an unknown quantity at this point
Default
Just got mine in the mail today still have not picked up my Mountain Cat yet but knew I wanted this. The quality seems very good i agree and I am glad the install went easy for you. I am so happy finally someone took the time to make this kit one of the things I hate the most about cats mountain sleds. Can not wait to install mine and test it out.
  #3
Old 09-14-2017, 04:53 AM
ultrasks700 ultrasks700 is online now
Currently: twisting wrenches
ultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond repute
Default
Im glad someone finally grabbed the bull by the horns and came out with a plug-n-play kit. I did basically the exact same set up on my M-series a couple years ago but everything was spliced together. It is defiantly going to be a big improvement over the circa 2007 switch set up
  #4
Old 09-14-2017, 05:00 AM
Default
I see you installed so ODI grips too...I was wondering if the fluro yellow matches the green color scheme
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Cleaner handlebar setup Thread Starter — NLRichyJ Forum — Arctic Cat: Proclimb M Replies — 25 Last Post — 03-06-2017 05:17 PM
Thread — New handlebar setup on M800 Thread Starter — catothom Forum — Arctic Cat: Proclimb M Replies — 64 Last Post — 06-04-2013 12:27 PM
Thread — new handlebar setup on 07 dragon? Thread Starter — WXNic Forum — Utah Replies — 9 Last Post — 10-30-2011 10:51 PM
Thread — handlebar setup Thread Starter — ruffryder Forum — Performance/Modified Replies — 3 Last Post — 01-18-2011 09:54 AM
Thread — Best handlebar setup Thread Starter — switchback0410 Forum — Polaris: EDGE Replies — 8 Last Post — 02-14-2010 03:30 PM
