Over the summer, I put new power valve cables on because the cable housing was coming apart. Didn't do anything else to them, but now the servo motor doesn't turn. I'm pretty sure it is suppose to cycle when you first start the motor, but it doesn't do that, and the check engine light blinks. So I pulled off the motor and did a bench test. I hooked up the power leads to a 12 volt battery and it turned. To me, that would mean that it isn't getting the power to the motor itself to make it turn. The my lights works, so the stator is producing elctricity. My question is what do I check next? Is it the ECU that isn't sending the signal to power the servo motor, or is it something else? Thanks in advance.
