B
I have a 2004 ski doo summit rev and was wondering if the 37'' alternative impact a arms will help lay over easeyer and sidehill better? :face-icon-small-con
You guys can twist and tune all you want and when you get it to carve as well as you can - Then add 37 in. arms.will carve about twice as good .Simple geometry .How is your front skid shock and limiter setup? I prefer my shocks in the middle positions on the front, long strap and max the preload in the center shock and if your weight will allow run the rear torsions in the middle.
This will induce some ski lift when climbing, however it will make the sled super easy to lay over. A blip of the throttle and hang your weight off to the side you want to go and she will lay right over.
I was given this setup advise when I started to explorer the "carve" and the side hill, with the added advise to ride it this way for a few rides. This will help you learn what the sled likes, then start to add ski pressure and reduce transfer to your taste.
Honestly the REV needs no help carving... I find most are just pourly setup or guys are trying to hard.
Why not just use one ski in the middle?
I have slp spindles and the sled carves wicked easy
I'm 240 in my street clothes.
Was looking at getting these too. Does the shocks that I have on the stock front end work with th
e 37 inch wide front end or do you need different shocks.
