I posted this on Doo Talk aswell. So I bought a new 09 xp154 last year and it ran fine for about two trips then while in chappel after a huge dump of fresh the thing was bogging on hills. First I thought it was fowlled plugs but that wasnt the case, intake plugged, not the case, and the clutching was fine as far as I could see. It would run fine except while trying to pull a hill, it would bog and wouldnt let me make the climb, had to run the lake for a while then it worked fine except when I tried to pull a hill, same thing. Im leaning towards the overheat issue when the ecu retards the timing. Has anyone else had this isssue? The dealer tested the dpm etc and found no codes and everything to be working fine but that's at the dealer not on the hill. They want to send me to the hills with a new ecu and dpm to try if I have the same issues. HELP.
