2009 M8 Belt Replacement
Tempest
36
Twin Falls, Idaho
I picked up my 2009 M8 SP 162 last friday. The question I have is, how do you remove and replace the belt with the new helix. The old sleds(2005-2008) were fairly easy. But the new sleds have the reverse notch in the helix, which makes it difficult to open up the secondary clutch. Is there a special tool? My dealer was going to look into this. We had a tough time installing the belt from the factory, as they are shipped not installed. Any thoughts?
M
minet
143
how to is illustrated in the release pdf . , but you just flip the end cap over
page 145ish
good reading page 141-150 ~
K
Jan 19, 2008
1,473
84
48
Utah
1st thing is to never go back to that dealer again! Especially if he doesn't know how to change a belt and will "look into it".
Seriously, every dealer should know this and if not it is in the owners manual and I'm sure its in the service manual also.
Also I hope they didn't pry the belt on.
Remove the secondary bolt, collar and washers.
Set the washers aside, and thread the bolt and collar back in.
This will spread the sheeves and allow you to change the belt.
Mine was still a little tough to do, so I use an extra large washer along with the collar to spread the sheeves even further and make it easier.
M
minet
143
i got it at work but i got it off achat ,, lemi see if i can dig up a link ,, i linked it to snowwest at least 4 times already
