Note: this_feature_currently_may_not_be_available_in_some_browsers
So I decided to also get an additional VR to separate out the headlights from the ECU. I bought the SPI replacement for like $36 on ebay. Anyways I bolted to the clutch guard with a couple 1/4" bolts. Here is a couple pics of it mounted. Better to be safe than sorry.
I mounted like this so it wouldn't rub on the oil tank.
As a side note:
If you have a Boondocker Turbo with the fan for the intercooler... you will not need to run resistor as the fan pulls enough power from the lighting circuit....But I would still run the separate VR for an extra margin of reliability.
For those who want to buy a resistor setup, her ya go.
http://stores.mountainfithoods.net/pro-ride-headlight-delete-resistor-plug-n-play/
So after only a couple hundred miles on my 14' pro with the headlight delete and running the separate VR, my hand warmers have all but stopped working. Initially they were so hot even on low that I had to cycle the them on and off to keep my hands from burning. Then the next trip, I could barely feel them. I think the VR may be toast now. I order the mountain fit hood resistor and will order another VR and see if that helps my warmers out.
