R
I am parting out 2 Ski doo Summits this summer. They are complete running sleds that will be torn down as they do not get used any longer. If there is anything that you are after that I might have missed just let me know. Prices are relative and most shipping will be done with flat rate boxes for cheapness. Multiple items can be combined to cut down on shipping costs.
95 Ski Doo Summit 583
$10 Rear Bumper
$25 Taillight
$100 Rear Suspension
$50 Driveshaft
$200 Track (136x.75)
$40 Fuel Tank
$50 Speedo (3611 miles)
$50 Rh Trailing Arm
$100 Chaincase
$15 Brake Rotor
$15 Jackshaft
$30 Secondary Clutch
$10 Steering Shaft
$15 Throttle Block
$30 Throttle Cable
$15 Brake Master Cyl
$35 Fuel Tank Shroud
$50 Tach
$20 Dash Panel, Headlight shroud
$30 Headlight
$50 Radius Rods and Ends (all)
$35 Front Bumper (S Chassis)
$10 Handlebar Clamps
$15 Clutch Cover
$100 Primary Clutch
$25 Belly Pan Supports (S Chassis)
$10 Coolant Tank
$10 Oil Tank
$25 Airbox
$40 Exhaust Pipe
$40 Silencer
$15 Motor Mount
$10 Brake line
$30 Bulkhead
$15 Brake Caliper
$50 Idler arms and spindles
$100 Carbs
$100 Cdi Box
$25 Coil
$20 Coolant Hoses
$500 Engine (w/ Manifold, Intake boots, and Oil pump)
99 Ski Doo Summit 500
$10 Rear Bumper
$25 Tail Light
$15 Mud Flap
$150 Rear Suspension
$50 Driveshaft
$40 Fuel tank
$50 Speedo
$50 Rh Trailing Arm
$100 Chaincase w/ gears
$15 Brake Rotor
$15 Jackshaft
$10 Steering Shaft
$15 Throttle Block
$30 Throttle Cable
$50 Brake Master Cyl (Brembo)
$30 Fuel Tank shroud
$50 Tach
$30 Headlight
$50 Radius Rods
$35 Front Bumper
$15 Clutch Cover
$100 Primary Clutch
$10 Coolant tank
$10 Oil Tank
$25 Airbox
$40 Silencer
$15 Motor Mount
$10 Brake Line
$30 Bulkhead
$30 Brake Caliper (Brembo)
$50 Idler arm and spindles
$100 Carbs
$100 CDI Box
$25 Coil
$20 Coolant hoses
$10 Rear Bumper
$25 Taillight
$50 Driveshaft
$40 Fuel Tank
$50 Rh Trailing Arm
$100 Chaincase
$15 Brake Rotor
$15 Jackshaft
$10 Steering Shaft
$15 Throttle Block
$30 Throttle Cable
$50 Tach
$30 Headlight
$15 Clutch Cover
$100 Primary Clutch
$10 Coolant Tank
$10 Oil Tank
$25 Airbox
$40 Exhaust Pipe
$40 Silencer
$15 Motor Mount
$10 Brake line
$30 Bulkhead
$15 Brake Caliper
$100 Carbs
$100 Cdi Box
$25 Coil
$20 Coolant Hoses
$10 Rear Bumper
$25 Tail Light
$15 Mud Flap
$50 Driveshaft
$40 Fuel tank
$50 Speedo
$50 Rh Trailing Arm
$15 Brake Rotor
$15 Jackshaft
$10 Steering Shaft
$15 Throttle Block
$30 Throttle Cable
$50 Tach
$30 Headlight
$50 Radius Rods
$35 Front Bumper
$15 Clutch Cover
$100 Primary Clutch
$10 Coolant tank
$10 Oil Tank
$25 Airbox
$40 Silencer
$15 Motor Mount
$10 Brake Line
$30 Bulkhead
$100 Carbs
$100 CDI Box
$25 Coil
$20 Coolant hoses
