H
Seized it? Change that bearing out, beat the bottom dent back to shape, jb weld if need be, fill with atf and ride on!
You had a factory aftermarket skid plate on? How did you get the scuff marks on the stock plastic skid?
Call Specailty Motorsports in Spruce Grove Alberta. 1-780-960-0571
Ask for Rob. He has the C3 belt drives there and can ship right away.
Jep. Factory skid plate is too weak....... Useless..
yeap, it is the plastic reinforcements in the original protector that has pushed the aluminium up. cast aluminium is weak..
Ordered a beltdrive kit from TKI cnc!
everything was spot on and the service from tom is 1 of a kind.
Had a testdrive for 20 minutes just too check belt tensioner etc and dont know if its just my mind because i have a belt drive but man does it feel responsive! cant wait for the weekend and have a side to side test with a buddy of mine with the same sled with chain.
if you can afford it dont hesitate too contact tom, this was well spent money!
And yes the klim sticker makes the oil better! xD
Looks great!
You might want to put some heat reflective tape on the side of the oil tank that is closest to the can as a precautionary measure.
I have one installed on mine and I absolutely love it!
