Edgey------Iluv2fly
Edgey setup
" 09 M8 153 std with the slp pipe kit with slp blue/pink (140/340) primary spring 65g cat weights in the sec stock orange spring shift asst. 42/36 helix with rock rollers at 11,000 only pulling 78-7900 rpm."
RickM setup
09 M8 153 sp with slp pipe kit, speedwerx white./red ( 125/340 H5) primaryspring, 68 cat weights. stk orange spring with shift asst, 40/36 helix with rock rollers at 11000, pulling 8000 in powder or on hard pack road.
Iluv2fly setup
160/310 primary spring, 74 Mtx , 8200 Rpm 9000 feet, but running slp porting.
Iluv2fly may be running the best performance, but i chose not to shim spider for mtx weights. and not port cylinders to have to run control box.
I test ran cat 65 weights and lost track speed, edgey and I are almost identical in setup, I weigh ready to ride at 200 lbs. slp measures their springs different than cat & speedwerx do. that may be the difference in RPM for edgey. I may have to drop to a 67 cat weight to gain the 100 RPM or take a little off the tip of the 68's. i just like to load the motor as hard as i can. my M8 is running really well but I would like to see what it really can do at the RPM SLP says to run it at. Trying to split hairs right now. Thanks for the help
RickM
