Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 02-23-2016, 02:13 PM
RyanC111 RyanC111 is offline
Currently: Thinking Snow.
RyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond reputeRyanC111 has a reputation beyond repute
Default 850 SP vs X
Other than colors here are the differences I can see (based on spec sheet):
  • Weight - ~6 lbs lighter for the X
  • Running boards
  • Suspension - HPG vs. HPG Plus
Using the build your own tool the price for the SP would be $13,349 and the X $13,899.
Do you guys think that the $550 premium for the X is a worthwhile investment? I'm just not familiar enough with the benefits of the HPG Plus suspension parts over the HPG.
Rate this post: Yes | No
  #2
Old 02-23-2016, 02:19 PM
Chewy22's Avatar
Chewy22 Chewy22 is online now
Currently: Not set.
Chewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond repute
Default
Where is the -6lbs gained on the X? I know it's not a lot but find it very interesting, since the sleds appear to be the same other then the boards and shocks. I don't think the -6lbs comes from those, so what else is different?
  #3
Old 02-23-2016, 02:33 PM
zenk zenk is offline
Currently: Not set.
Basic Member
zenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond reputezenk has a reputation beyond repute
Default
also different bar position, different bars, different riser.
  #4
Old 02-23-2016, 02:41 PM
KTMDirtFace KTMDirtFace is offline
Currently: Not set.
Basic Member
KTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond reputeKTMDirtFace has a reputation beyond repute
Default
Crappy shocks, vs. Re-Buildable crappy shocks.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to KTMDirtFace For This Useful Post:
RyanC111 (02-23-2016)
  #5
Old 02-23-2016, 02:49 PM
AkSledHed AkSledHed is online now
Currently: Need more snow.
AkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond reputeAkSledHed has a reputation beyond repute
Garage
Default
Quote:
Far as I can tell, it's in the shocks, handlebars/risers (tapered X, SP 7/8's), and running boards, everything else seems to be the same.
The Following User Says Thank You to AkSledHed For This Useful Post:
christopher (02-23-2016)
  #6
Old 02-23-2016, 03:19 PM
snoblind04's Avatar
snoblind04 snoblind04 is offline
Currently: having a blast on my mpi turbo
snoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond repute
Default
It looks like the bars/risers are the same. 4lbs could be in the shocks alone since its steel vs al body
  #7
Old 02-23-2016, 03:21 PM
live2beel live2beel is online now
Currently: Not set.
live2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond repute
Default
4 year warranty on spring check vs. non
  #8
Old 02-23-2016, 03:27 PM
dejadoo's Avatar
dejadoo dejadoo is offline
Currently: Not set.
dejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond repute
Default
I would go with the X to get the running boards
and the mostly black color
  #9
Old 02-23-2016, 03:36 PM
i'llDooit i'llDooit is online now
Currently: summer sucks
i'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond repute
Default
6 pounds= 550.00
They discounted it at 100 bucks a pound.
  #10
Old 02-23-2016, 03:39 PM
Default
Quote:
You can spring check an SP too . . .
  #11
Old 02-23-2016, 03:50 PM
Smoke Show's Avatar
Smoke Show Smoke Show is offline
Currently: Buy my Nytro, please.
Smoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond reputeSmoke Show has a reputation beyond repute
Click Here to Register
  #12
Old 02-23-2016, 04:16 PM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
  #13
Old 02-23-2016, 04:20 PM
Garage
  #14
Old 02-23-2016, 04:58 PM
Ace Freely Ace Freely is online now
Currently: The problem with common sence, is that it isn't that common!
Ace Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond repute
The Following User Says Thank You to Ace Freely For This Useful Post:
i'llDooit (02-23-2016)
  #15
Old 02-23-2016, 05:00 PM
Currently: Not set.
Basic Member
  #16
Old 02-23-2016, 06:14 PM
Garage
  #17
Old 02-23-2016, 06:56 PM
warreng417 warreng417 is offline
Currently: Not set.
Basic Member
warreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond repute
  #18
Old 02-23-2016, 07:09 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
  #19
Old 02-23-2016, 07:33 PM
  #20
Old 02-23-2016, 08:01 PM
dejadoo's Avatar
Currently: Not set.
  #21
Old 02-23-2016, 08:13 PM
MtnRidr4Life's Avatar
MtnRidr4Life MtnRidr4Life is offline
Currently: Not set.
MtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond repute
  #22
Old 02-23-2016, 08:47 PM
Tahoepow Tahoepow is online now
Currently: sharpening my cat claws
Tahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond reputeTahoepow has a reputation beyond repute
Garage
  #23
Old 02-23-2016, 09:16 PM
sledking120's Avatar
sledking120 sledking120 is online now
Currently: Ready to ride
sledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond reputesledking120 has a reputation beyond repute
  #24
Old 02-23-2016, 10:56 PM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
  #25
Old 02-23-2016, 11:08 PM
KingCon KingCon is offline
Currently: Not set.
KingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond reputeKingCon has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 850 E_TEC Thread Starter — dejadoo Forum — Ski-Doo: REV Gen 4 Replies — 109 Last Post — 03-11-2016 12:12 PM
Thread — RKT 858 really only a 850 ??? Thread Starter — Going West Forum — Polaris: Pro-Ride Replies — 20 Last Post — 12-11-2013 09:06 AM
Thread — 07 700 Dragon $4,850 Thread Starter — rattlesnake Forum — Polaris (Swapmeet) Replies — 7 Last Post — 01-13-2011 09:40 AM
Thread — Ubr 850 Thread Starter — mtnrider406 Forum — Engine/Engine Parts (Swapmeet) Replies — 11 Last Post — 05-20-2009 10:21 PM
Thread — 850 Union Bay Thread Starter — Nossman Forum — Performance/Modified Replies — 2 Last Post — 02-29-2008 03:27 AM
no new posts
