A
I understand coupling. My question was, does it work on stock suspension arms/geometry. Sorry for the confusion.
It will work.
Did the same thing on my older M skid. Doing it to my '12 skid for this season too.....
Nice thing about coupling (even on a stock sled) is you can run a lower initial spring rate to get it to be a little more supple in the pow and on the trail.
Had to re-valve the front shock and run the spring all the way lose as well. By the time I was done with the first skid, it rode and performed as good as any aftermarket skid.....
Below is the R&D skid. Not pretty, but functional for testing....
Clicky
Looks good, was thinking of doing the same thing to my sled this winter. Where did you guys get the plastic from for the blocks? and are they adjustable? It looks like you can rotate the ones on Thunders to adjust the travel. How did you guys figure the distance between the arm and the blocks?
Should help, but with that shorter rear arm its still going to wheelie pretty good. Need to extend that rear arm, also take it easy on landing on the tail since there is that much skid still hanging out the back, if it does collapse hard it could noodle it.
