Life must be rough. Lol
I'm currently running 18.8 grams of weight in my 872 T3 with 30/70 fuel blend and the thing pulls like a bat outa hell!
What elevation are you riding?
Ride report. Man I have been busy, riding a lot and working a lot so I haven't been on here much. So I have a couple T3s as I said and a ProLite 900 cat. The Cat has a belt drive and a 174" 3" track. The HUGE difference I have seen is the Trygstad engines just run perfect every single ride. I have had nothing but problems with the Cat. I just can't get it to run well all the time. Current issues are it runs like crap from 4500-6500. It always cleans our and pulsl to top RPM when you pin it but its just been a series of issues. It just hates running part throttle down the trail and the throttle response is not good. I love the chassis and how well itll pull my big *** out of a ravine or hole but I would trade if off for another t3 with a TRygstand engine. My 872 engines run perfect. just like a stocker but with more power everywhere. They also seem to run super efficient and dont burn much if any more gas. The two engines/sleds i sold to my buddies also work perfect. One I sold to a buddy who is REALLY hard on stuff. I swear he can break anything and his has run perfect and is on it's third season. My other buddy had to ride some stockers for new guys last weekend as it was really deep and wet and he said REALLY noticed the dif in the hard conditions. Said he really didn't enjoy it and missed the power and how playful it makes an XM T3. Im running Roosterbuilt clutches and I am super happy with them too. 2 other riding partners are riding turbos and they are just always having issues. In the 3000-7000' elevations we ride in Washington I think the Trystad 872 is a WAY better choice especially for tree riding. I do ride some in WY and at 8000-11,000' the turbos have an advantage but my 872 still makes good power, much more than a stocker.
I agree with you. I own a 872 Trygstad and I've had two clutch kits in it. Rooster built and now I have daves kit in it. I can't get it to run better than my stock etec. I've had it look at by multiple people and no one can find anything wrong. It pulls its rpms and holds it right at 7900-8000. Engine runs great just pulls like a stock 800. We rode with two guys last year and one this year with 872 that all said the same thing. They run a little better than stock but it's hard to tell. Not worth the money! My buddy has a stock etec same sleds/tracks and he climbs everywhere I do with the same track speed and will beat me in a race down a trail. I've talk to Dave multiple times and he's the farthest thing from a stand up guy. Won't do anything for me or anyone else with the same problem. His 872 was the biggest waste of money I have ever spent. Go with a y pipe you will get more power out of it and won't have to spend $3500 on a 872 install and clutch kit.
It will pull 6-7 mph more than stock sled same track. Doesn't sound like much but it's huge.What do you guys think you picked up in track speed? 872 vs good running stock sled,same track length. Thanks
Pm me if u want a clutch set up that works
this is a copy/paste from a comment of mine on the 1st page
**872 with rooster clutching, 20T top gear, stock 163x2.5 track was seeing 47-48 mph track speed
**stock 800 with DJ mountain ramps and primary spring (secondary is stock), 7T drivers ,163x3 track, 21T top gear, about 75lb heavier rider.......i saw 40-41 mph speeds on the same hill. now, since i have 7T drivers on my 2014 sled that originally had 8T drivers, that throws my speedometer off. i was told the magic number is +8% high. (41mph x .92 = 38 corrected mph) so to sum it up.....same hill, same day....
872 - (still in "break-in" if that matters) / rooster clutching / 2.5'' stock track - 48mph
800 - DJ clutching / 3" camoplast X3 track / 50-75lb heavier rider - 38mph (corrected 8% for smaller drivers)
What elevation? 10mph higher track speed seems inflated to me. But might be possible at a lower elevation. I'm seeing about 42-44mph track speed. 5-6 over stock. And a rocket outta the hole!!!
Raced my 872 w/ 155 poo track against my buds 880 w/ 3" 163. Both carbed. 8000' about 2.5' of fluff, no base. Started right at the base of hill. I was 51 mph on 872, 880 was seeing little over 45. I jumped him and then he blew past me at mid hill. We're roughly the same weight. Track lug height really effects mph, but the opposite happens quite often w/ ground speed. Look at the new axys numbers being posted, very low, but they seem to perform in the deep snow.
Wileybird, 433 work well, just make sure you get a low enough finish on primary spring or be prepared to add a lot of weight. It'll feel like to goes really flat otherwise. 260 or 290 finish work well. Either 135 or 160 start depending on what you prefer for engagement.
