PRO MTN WINDSCREEN
Jooohan87
Aug 28, 2011
36
Hello
Anyone using the pro mtn windscreen bag? Is it worth the upgrade from the original windscreen? Is it any capacity to talk about? I like the look of it
Suzzy-Q
548
174
Mackenzie B.C. Canada
I like mine, but I do think they could have made it a bit bigger for storage, it’s still better then having a normal windshield that I’m gonna crack a few time a year
45
Anchorage, Ak
I'm waiting to get one of the Skinz Next Level windshield bags when they become available. They are currently backordered. I had one on my PRO RMK and I really liked it.
ultrasks700
462
172
MAINE
I got one on mine, there is a decent amount of storage, enough for a pair of gloves, couple candy bars, wallet, etc. I like it so far
Sent from my SM-G955U using Tapatalk
sno*jet
2,826
1,298
hope they are better than the one for the proclimb (i doubt it). complete junk.
sucks too, as id rather support usa made products then chinese.
love the cat bag. a little tight going on but stays tight. the skinz would not mount up period.
i recommend replacing the goggle bag with the plastic vent cat makes for that spot, and stowing those goods in the windscreen bag. then the heat can pour out of that area, at least on the proclimbs it sure does. i believe the sno pro or ERs had the vent for asssender models.
Dec 15, 2020
Hey, I have a 2020 alpha one and I’m having a hard time mounting the Pro Mountain Windscreen. They are round pegs in square holes, any pointers? Anything would help, thank you.
Old & slow
727
393
Alberta
I like the storage in mine works good, when I mounted it I put all the rivets through the bag holes first then place the bag on the sled and pushed then down. One thing I did do was line up the slot to remove the rivet so you can get at it with a small screwdriver. Just makes it easier to remove.
Dec 15, 2020
I can’t seem to get the rivets to seed to the machine. They just keep popping out. Wasn’t sure if someone else was able to mount using the rivets the bag came with or if they had to use something else. The original bezel was screwed in but those screws won’t work with the bag.
idacatman2
206
Ashton, ID
Best way I found to install was put the rivets in the bag then seat them down into the holes then push the inner part of the rivet down from outside the bag.
