A
Installing my 15 ST kit on a 2013 CRF450 and the chain seems to long at 69 links. It will hit the track, I'm running a 13 tooth sprocket any ideas what could be wrong? I had a 13 ST kit on it last year and it fit fine.
I am having the same situation.:face-icon-small-disInstalling my 15 ST kit on a 2013 CRF450 and the chain seems to long at 69 links. It will hit the track, I'm running a 13 tooth sprocket any ideas what could be wrong? I had a 13 ST kit on it last year and it fit fine.
drop 1 tooth in your chain case
of course they do! every '15 mountain horse owner who wants to dial their gearing should think about getting one. I'm prepared to dial my climbing gear on day 1! a touch up or down depending on if you put it top or bottom. I'm pretty sure the tensioner inside the cover will work just fine! I think it was like 70 bucks, I'm sure 9milers is just as good!
Thanks, I like that idea- dirtrebel-the old kits had 17/21 the new ones have 17/17
so are the new kits geared up?(taller) I know they changed driver size? also how does the engine drive sprocket size relate to the chain case sprockets? (on a dirt bike 1 tooth Front=3 in the rear)
