300 psi compression
the gman
337
106
I know all gauges are different and just trying to get a base line so my 300 has gores porting with the ktm Sx head and Eric tightened up my sqwish from last year and I have 225 psi. This setup is for 3-6000 feet and was setup to run on pump gas. This just seems high, anyone have any ideas....thank you. Garry
This test is at 1700 feet
Summitseeker
1,092
446
83
British Columbia
Following.... That seems really high. I have the same setup as you, I have not done a compression test but 225 PSI would be hard to kick over! I will do a compression test on mine this week and see what mine reads.
chumbilly1
1,278
245
I have two different heads (300sx) modded by cycle playground and they are 225 and 230psi. I requested 50% 110 @ 2k and 5k elevation. This spring I tried to run the bike @ 2k with the 230# head and it literally would not rev at all. Switched heads and runs fine. I may use a thicker base gasket this winter to raise the exhaust port and lower compression # slightly. I feel this is the edge of too much compression.
the gman
337
106
Did you ever check your sqwish chumb? I checked mine before I sent in my jug and head for port work and after. I will check my records and post what eric set it at, just wondering if it's too much. Thanks
M
mtn-doo
1,315
661
Kalispell, Mt
Hey Garry, yes. too much compression will kill your top end. Zero over-rev. Try the .075 base gasket. I think you are currently running the .050.
the gman
337
106
Talked to eric today and I had a sqwish of .072 and comp. of 185 before sending in my jug and head for porting. He did his work and tried to get my sqwish to .050-.055 which would of got me to 200-205 comp. Problem was my base gasket I did my sqwish with was .024 and the common base gasket is .020 which is what I used for my rebuild. My sqwish was .046 with the .020 base gasket which gave me 225 psi. Head is on its way back to eric to cut .005-.010 which with the common .020 base gasket should get me right at the .050-.055 sqwish he says is safe for pump gas at 3-6000 feet. I will post sqwish and psi when my head gets back. Thanks for the responses. Garry
the gman
337
106
Update on head work,got head back from forward motion and sqush is .054-.056. Psi is now a more reasonable 210. Hope it runs good on pump gas.
chumbilly1
1,278
245
I have not gotten into checking sqish. I look at it like suspension valving. I am simply better off to let a professional do their work and I will go to the jobsite and do mine. Just not enough time in life for me to learn it all. Maybe I am a slow learner?? I am going to add some basegasket this year though as I feel my topend was being held back by the high compression. Another thing I have noticed about high comp engines is the carb signal is so much stronger they are more difficul to jet. It will be interesting to see what a SC does when you change port timing and head.
wwillf01
2,790
616
Heber Ut
I just had my 300 ported by Eric gore and I have a Lectron... I had to richen my rod .75 of a turn... This is a good bit richer and I turned the power jet a half turn richer. But once set your are good to go;)
Sent from my iPad using Tapatalk HD
chumbilly1
1,278
245
That is interesting, with the Dick's modded Keihens I have been using, I end up using leaner brass across the spectrum. I always figured this was do to increased velocity and signal. Could also be that I am running more race fuel than is needed I guess.
wwillf01
2,790
616
Heber Ut
I know for mine the amount of race gas I use makes a huge difference.... I use 88 non ethanol 3 gallons with 2 gallons of 110... 40 to 1 with a good synthetic... I find if I go to high on the octane I loose power....
wwillf01
2,790
616
Heber Ut
The other thing is to make sure to run a step colder plug... I found with the higher compression it seems to run smoother.
M
mtn-doo
1,315
661
Kalispell, Mt
Having run the Smart Carb with modded two strokes for some time now, I can report they simply respond to signal. Pretty cool. Port timing , ignition timing etc. The signal is responded to with zero changes in AFR or EGT. They don't have jets that only deliver one amount of fuel. They respond to signal, even load factor not throttle position. Pretty sweet
