looking at an m7 05 or 06'. are there any issues that you cat guys can fill me in on before i put my girlfriend on what ive heard to be a reliable sled??
Make sure and ask if the sled has had any wiring issues, specifically at the rear of the sled. Some had a spot where the wires would rub on the tunnel and then it would confuse the ecu. Back near the tail light.Thought of something else to check,,, look at the D/D on tunnel side, look for any signs of gear oil leakage. Ask owner how often the D/D oil was changed. If he's honest you should get an answer accordingly.
well some of the issues you guys list im going to have to find out for myself the sled only has 318 miles on it and im picking it up saturday. thanks again for your assistance. is the wiring issue right under the back seat? i know some about the attack 20 but shes not a climber so it should be perfect for her, doesn't it stop very well on the downhill? i assume your talking about the diamond drive does a seal go out that causes problems? thanks for your insight.
