Note: this_feature_currently_may_not_be_available_in_some_browsers
I have read nothing but good things about Boondockers sidekick turbo set up. My question is; how many(or has anyone) added the kit prior to the 18 hour "break in" period?
Put the side kick kit on mine before I pulled the rope for first time. Should be fine just hard not to rod on it too hard before the motor is broke in. Sled runs strong and it is a sweet pull and go system. The problem I am having is exhaust valve codes and then it dies, tow it back and it fires right up with no problems or codes, but sounds like more people are having this issue and it's the harness connectors on the axys are not very good so going to take them all apart and grease and zip tie. Sounds like that will fix the issue, tomarrows project then test ride.
Are all of your kits just the base kit with no add-ons? Or did you guys upgrade anything?
Thanks all for the replies. Ordered the sidekick last night w/ the MTA oil-less upgrade. This will be my first turbo and I am looking forward to it!
Did you guys do the install yourself?
I am in eastern Nebraska so performance shops are pretty limited around here. Install seems fairly straight forward....we will see.
My sidekick has no upgrades.
I had a couple of my buddies help me do the install it took about 6-7 hours. The install is very straight forward.
Why would you need a intercooler at lower elevation vs high? At lower elevations you are going to be making less boost. Sounds to me like theyre trying to up sale you...
I made the decision on the inter cooler, they said I needed the tial. When I ride higher elevations in Wyoming where 90% of this sled is ridden it will run around 7lbs and with ptp switch around 9lbs, maybe not needed but figure it would be more consistent power. Maybe it was a waste of $$$?
