N
Hello all, BD RG turbo, simple tuner ADA, EBC... Been chasing a boost leak, symptoms are that it engages at 4k, and has a heavy bog until it reaches 5200 then it'll pull your arms off. With any resistance from a stop it sputters for about 5 seconds before reaching enough boost to kick in, around 5200 rpm.
Put in new stock reeds, throttle body reinforcement, made sure airbox has good connection with the tb boot, same with airbox to intercooler. Replaced exhaust bellows, cleaned exhaust valves. Have yet to replace the fuel filter, probably desperately needs it.
Questions.... Where else should i be looking? Is it possible that my egt connections are suspect? friend tells me that i should be using a hi temp gasket style sealant on all my exhaust fittings, pipe, Y, opinions? Any other suspects on the boost leak list? Could a neglected fuel filter cause these symptoms? Any input would be much appreciated.
