Does FTX have a alignment tool for offset or a measurement to use?
Have you guys done any baselines on turbo M8's yet?
Yes we have.
Running a BDX lite drive in a Polaris IQR chassie & hoping to gather some clutching advice to help solve my belt slipping issues. Both primary & secondary have a build up of belt rubber in the full shift postion.
EQUIPMENT
910 polaris twin - Equal to piped M1 power
3" lug 162 track & 8 tooth 3" pitch drivers
P85 with 10-64 weights & almond spring
BDX drive with 57/63 gearing & 10.4 secondary
RKT str cut 38 helix & green spring with 3rd hole twist
UltraMax XS809 belt
No speedo.
ALIGNMENT METHOD
Use Polaris alignment tool to get clutchs inline & allow.040" for engine twist.
Shim secondary to get belt riding in center of primary. Some trial & error. Does Fast Trax have a alignment tool for offset or a measurement I could use? Not sure my center to center but able to set belt deflection to get belt riding about .1875" out of secondary. Do have abit of belt squeel if stopped.
PERFORMANCE
belt slipage, rubber build up on both clutch faces in full shift area
400- 500 rpm under target in deep powder
Accelerates fairly strong on bottom & feels flat on top. totaly stops up shifting but as mention not pulling full rpm.
Top speed on road ok, short blasts only. 3" track holding up so far.
Is belt getting wet or little misted? Havn't felt any indication of slipage.
Do I need to have more belt side force on secondary? Maybe secondary is allowing belt to shift to quick? My set up is close to what some Cat's are running & sounds like they are working good. Is misalignment an issue or center to center distance a problem? Is belt compond an issue?
baselines were finished last season on turbo 7's and 8's. 3200 feet and 6-9000'. 8# , 12# and 14# set ups-we prefer the SLP MTX in a p85 with a turbo but the choice of weight is yours to decide.
Durability is not an issue-turbo or otherwise, unless you fall behind on your clutch maintenance.
Curt
What weights and spring rate would you recommend on your setup for 8000-12000 feet, 8-12 psi of boost?
How much does it cost tohave a polaris p85 clutch set up to run on a m8 and who out there does that kind of work for clutch setups, thanks.
Why? Get the spider shims set-up correctly and add one of these for alot less $$ and you'll have no clutch worries. No I don't have any connection to Lonn other than using his adjustable weights since '98.
http://www.thunderproducts.com/911 Clutch Cover.htm
I put the p85 on with a properly matched secondary setup (this is key)
