Note: this_feature_currently_may_not_be_available_in_some_browsers
Here is the detailsWhats the skinny on this? Similar to vehicle flash/tune?
Here is the details
"PRODUCT ANNOUNCEMENT: NATURALLY ASPIRATED ECU REFLASH
Looking for improved throttle response, increased horsepower and torque along with better reliability from your naturally aspirated Ski-Doo, Polaris or Arctic Cat? Welcome to the Silber NA REFLASH.
We have spent the last year behind the scenes tuning different sleds to enhance factory performance and improve reliability. Taking what we have honed for many seasons on the boosted side of things, we are now applying the same tuning process to the naturally aspirated side of things.
We are now ready to release a line of ECU reflashes for the following naturally aspirtaed sleds.
Polaris 800 HO (2016 to current)
Arctic Cat Ctec 2 800
Ski-Doo 850
We also spent a significant amount of time tuning the more popular big bore and stage 1-4 offerings by many manufacturers including the Trygstad 927. We had immense success with our 927 tunes on the race course, and are thrilled to offer it to big bore customers looking for better performance all the while ditching the antiquated control box.
Some of the highlights of the ECU reflash to a stock sled are below:
6-10 HP (Depending on Year, Make, Model)
Improved throttle response
Improved oil pump calibrations
Improved Air/Fuel Ratios geared toward maximum output and dependabiity
Improved logic with sensor inputs
Improved timing calibrations
Torque gains throughout the RPM range
Easily returned to stock , if necessary
Custom Tunes available depending on current workload and travel schedule. Email us for details.
Please contact us anytime with questions or concerns=
Pricing: $350; add a flash cable for a $600 total"
Can Polaris see a footprint of this if warranty work is needed if flashed back?
No doubt the reason for a $250 add on will be to flash back to stock.
Hardly, the electronics are not cheap to build the adapter to allow flashing. Its more then just a simple little jumper cable. Just look at the current alternative, a power commander, your looking at 300-500 depending on fuel/ignition options, and the tech still isnt nearly as capable and has to be left installed on vehicle. Buy one adapter and you can flash all the sleds you want with it (you just need the vin locked flash for each vehichle)Ridiculous price then.
$350 for a ECU flash is ridiculous?
Did u miss the full price? $600. Yes that’s rediculous for a flash with only 6-10hp gain.
Ya I did not miss the price... Like said there is many Dealers/Customers around with the cables. Worse case you mail it in quick... The price is $350 for the flash..
