October 3, 2011 Subject:800R E-TEC Piston Replacement No. 2011-18
PROBLEM
Under severe mountain riding conditions, piston
ring locating pin may not meet durability requirements
and may fail leading to severe engine damage.
SOLUTION
Replace pistons with a new design ONLY if the
vehicle meets the following requirements:
– Vehicle used generally at an altitude of 1 200m
(4,000 ft) and above.
– Vehicle has reached 2 000km (1,200 mi).
NOTE: Pistons replacement is not required PRIOR
to stated mileage.
Campaign no.: 2012–0004
October 3, 2011 Subject:2012
Summit X RAVE Valve Components Rubbing on
Countershaft
PROBLEM
The RAVE valve hoses may be incorrectly routed
and the check valve manifold may be incorrectly
positioned. In such a case, parts will rub on the
countershaft resulting in RAVE malfunction.
SOLUTION
If needed, correct the RAVE valve hoses routing
and the check valve manifold position.
PROBLEM
SOLUTION
to stated mileage.
Countershaft
PROBLEM
SOLUTION
