Drivers are way easier as no one makes a S-chassis D&R kit any more. I was making some templates, but I kinda got sidetracked when I found out the new bulkhead I was using was a 380 and the cases are different...
With a D&R you need to move the driveshaft, AND the jackshaft. Takes a bit of grinding. Easiest done with sled completely stripped and belly pan off. Alot of work.
Changing drivers just needs to remove drivesahft, have new drivers installed, and change gearing in chancase to match 11%, so, you need to up your gearing to be the same. eg if you were running a 22/44 thats 2:1 you would need to go to approx 24/43 to equal the same. Your spedo is also going to be out 11% as well.
Thing with a D&R, now that I have that done, I can install 8T drivers and get a 3" track WOOOT!!!
