Sled will start then dies immediately
Dec 5, 2008
6
Provo
Hey guys
I have an 18 with about 200 miles. When I pull start it it sounds like a normal start then it immediately dies. I can start it with the throttle on and feathering it but once I let of the throttle it dies. Any ideas?
Thanks for your help
skippy
598
165
Try to tighten up your throttle cable. They stretch early on when new and get to loose and out of spec..
W
Wood
297
168
Hey guys
Just bought an ‘18 SKS with 700 miles on it. Same issue. Started fine first couple times in the garage, loaded it in the truck for a 2 hour drive. Unloaded and had to keep the throttle cracked to keep it running until it came up to temp and snapped out of it. Never had an issue starting my ‘16 in 3.5 years. Heard of some others with the same issue on 2018s but no explanation why...smoked bad and ran rough until it cleared up but fine the rest of the day. Seemed like it had a crankcase full of oil or gas or was just running super rich. Sled also loaded up a bit idling down some steep hills. I figured the mapping would have improved in 2 years....
KStrand
66
23
MN
Hey guys
Like skippy said above, prob need to tighten throttle cable. More than likely it’s loose and messing up your tss.
Dec 5, 2008
6
Provo
Thanks guys,
It’s the weirdest thing. So i think it was flooded and I held the throttle wide open when I started it. It worked but now it idles real high so I am gonna adjust the throttle. Thanks for all your help. Really appreciate it.
Scott
Scott Stiegler
69,618
11,737
W Mont
Remember the cable adjustment is right in the middle of the handlebars inside that movable rubber coating.
kgra
237
89
British Columbia
I don’t know if I’m missing something but in my experience if your throttle cable is too Loose it will not effect idle. Too tight of throttle cable will make it die. And there should be .030” free play. It’s probaly a bad tps sensor or tps out of spec provided everything is pluggged in and no other issues noticed.There are many posts on here how to check and adjust tps
sledhead9825
1,195
416
Agreed.. Only thing too much play in your throttle cable will do is, not give you full throttle. Adjust throttle cable to spec and check TPS.
Scott
Scott Stiegler
69,618
11,737
W Mont
The throttle cable tension advice that sticks out in my mind over the years is that you should be able to put tension on the flapper and there is just enough gap between the throttle and the block that you can stick a drivers license in there before the throttle cable moves.
TDR
89
53
Just went through this with both of my 18's. Bad TPS and the symptoms will vary from poor idle to fouled plugs. TPS is the weak link.
