hey guys, i have had this problem with a sled i've had for awhile but never been able to use, and it's back to that time of year!
so here it it. symptoms are start and idle great, but as soon as it is given throttle it bogs and dies out. but if you manage to get it past 5000 rpm it'll run at full power.
so far the stator, tps and tss all seem good, but it looks like the cpu is a 2001 or newer "circle" model, kicker being the previous owner put in the apv servo and "square" injectors (circle cpu).
here's a few questions i have
1. this servo is useless i assume (sled has a non apv motor), but will it affect anything being plugged in or unplugged for that matter?
2. being a apv cpu, will this cpu even work on a non apv motor?
3. all i've heard here is you can't mix injectors and cpu's, but a A-C mech i talked to said he thought you could, but he also works mainly on new sleds. what is your thought on this?
4. the cpu is flashing code 6. this does not exist on a 98, but any clues what it might be on a 2001 and newer?
any ideas or comments you guys have are welcome
thanks for looking
thanks for looking
