M
Was attempting to adjust my tps when I lost all voltage at the tps connection plug. Sled had been not wanting to idle, fouling plugs and didn’t like to go into reverse, ran great other then that(little rich off the bottom).
Currently getting no signal or volts at tps plug.
IIRC signal was low from the ecu when I started.
What does this mean? Bad ecu?
Sled fires right up and idles great but check engine light is on, bogs and won’t rev over 7500(limp mode?) cel was not on when i started.
Where do I start?
Where do I start?
