J
Maiden voyage over the weekend with my 07 M1000. Everything ran great until it started randomly die off idle, from a stop, with slight throttle and wouldnt want to restart until after a good 20-30 pulls.then it would gradually come back to life,spittng and sputtering, running alittle bit longer and cleaner, with every pull. First thought it was plugs, pulled and looked good, color brown and no wetness. It seemed like it wasnt getting the gas. I am thinking the TPS signal or something is screwing the PCM. Not getting any codes. No mods other than a can. Only had the 08 pcm update performed, needs the 09 flash. Earlier in the day it would start with one pull with slight throttle pressure. Re adjust the TPS?? Anything eles that may be a come problem to look for. Man I dont want to ride alone with this machine. I can barely move my arms today after pulling on that SOB. Its gonna leave me stranded if I dont get it fixed.
