N
Hey guy's is it possible to change your primary spring without any special tools. or is it something the dealer should do? thanks
why would i need a leverage tool i thought i would only have to take out the bolts on the clutch plate then put the new spring in and bolt it back down, sorry i have never tried this before! ps lovin the better boardsLike already stated you can change both the primary spring and the weights right on the buggy but do so with extreme caution as to not hurt yourself or damage your clutch by wedging and leveraging tools. When a leverage tool flies out and pokes out your eye or slams shut pinching the living $hit out your mechanics fingers you'll wish you'd pulled it.
Off course you need a puller and it's a really good idea to have a torque wrench for re-assembly.
It's best to pull....plus you can clean everything up easier. If you don't have a leverage compression tool take a simple cam buckle strap and wrap the clutch so that as you remove the bolts it stays in place then release the tension and slide her off. Two sets of hands are nice when reassembling...get it all lined up...push down by hand while the other person tightens the strap enough to get a good square start. Walla then you can tighten down your bolts safely and without stress.
