E
So I recently bought a 02 edge 800 rmk 151 that is in near perfect condition, has aftermarket tall bars, a can and that's about it. Well the I bought it from said it ran great, he used it for back country ski access, drained all the fuel out before summer and then when I went to buy it it had no spark all of a sudden, he didn't know why so I got it for $600, took it home and it had a aftermarket teather switch that was bad, unhooked it and it fire right up! Ran it a little and shut it off and let it sit for a few weeks, went out and started it and it was running on one cylinder then would randomly pop and run on two then pop and back on one again, seemed boggy on the bottom but as soon as you'd really throttle it it would come on to two cylinders and runs pretty good ( this is just riding around in the gravel outside the house). I tried a cool off my other ves motor, ran the same, bought a used CDi of eBay, same... Anyone have any ideas? Pulled the plugs and that side is wet and the other side is nice brown, compression tested it and both cylinders were spot on at 125, clipped the ends of the plug wire and same. Also notice that only the high beams work, the low beams don't, could be blown bulbs i havent dug into that
