2013 PRO LITE BY BLACK DIAMOND EXTREME
I
iq high marker
Dec 28, 2010
27
33
13
southern Minnesota
UNVEIL AT HAYDAYS!!!!!
THIS IS A LIMITED BUILD OF ONLY 50 MACHINES. THEY WILL BE OFFERING BOTH 153'S AND 162'S. THE MACHINE WEIGHS 430LBS AND COMES WITH 200 HP ON PREMIUM PUMP GAS, PULL AND GO. IT COMES WITH A BIKEMAN 900 BIG BORE KIT, LIGHT WEIGHT FRONT END AND REAR SKID. THIS MACHINE IS TOTALLY CUSTOM AND FULL OF LIGHT WEIGHT COMPONENTS. MORE DETAILS TO COME AFTER HAYDAYS. HERE IS A TEASER PIC.
BDX LIGHT WEIGHT 50MM THROTTLE BODIES
PC5 POWER COMMANDER
1 YEAR FULL WARRANTY
$16599.00 153
$16999.00 162
Can be purchased at Haydays or Cannon Power Sports in Cannon Falls MN with many delivery dates going west
PM ME WITH ANY QUESTIONS THANKS
http://www.cannonpower.com/
I
INDEEP
303
83
Post Falls, ID
Pretty good deal too. I think the pipe set for the big bore alone is pushing a g.
Just guessing but:
Bb 2k
Pipe 1k
Pc5 350
Boards 350
Thats $3700 not including install, clutching or any of the light weight parts. Plus a warranty to boot. Lets hope the belt problems are solved.
M
Nov 28, 2007
735
526
93
58
or
ssssssssssssswwwwwwwwwwwwwwwwwwwwweeeeeeeeeeeeeeeeeetttttttttttttttttttt!!!!! and its orange:) wouldn't your buddies sh!t when you show up and pull that out of the box??? very nice...
av8er
4,538
1,241
Kalispell, MT.
that is badazz
i've seen 2012 proclimbs used for around $9k, used turbo $3500 , sled that kicks the chit out of this one for under $13K, 215 HP PUMP GAS TURBO,
what a deal at only $16k BFD
I
INDEEP
303
83
Post Falls, ID
So you have a sled thats a year older, who knows it's history, without a warranty that weighs 60lbs more (turbo vs bb) for 3k less? Plus you have to install the used turbo kit and hope it runs. To each his own I guess.
R
rmscustom
2,181
1,801
Sled looks awesome!
How many gallons does the tank hold? Anything done to it so it doesn't eat belts?
backcountryislife
7,413
Dumont/Breckenridge, CO
For the folks that care as much about weight as power (like me) this is a pretty good deal. (and having a warranty on a mod sled is also pretty cool).
I'm still a turbo fan, but even at dealer cost the bdx parts are going to run me quite a bit to get this sled lighter.
boondocker97
4,074
2,792
Billings MT
Makes you wonder why Cat couldn't do this from the factory. Even if they added back the oil injection and a small headlight they could have cut another 10lb out of the chassis to make up for it and still be at 430#. I guess the factory exhaust silencer weight would be a little tougher to overcome but I think they can do it.
