E
Lean conditions can also show a low egt reading ...that is a bummer...
O2 sensor may help......
good news, i found a guy who will sell me av gas. other guy would not,
so i think i might run 100% av gas, will i worry about detonation? its 100LL grade,
should i be safe now at 5-7 pounds boost? maybe 10?
So did the prior owner of the box NOT use a rising fuel pressure regulator, too?
FYI, im not sure how jason or chris had your box setup, but i know they can be mapped to run w/o a rising rate regulator and should easily be able to fuel those lower boost levels even on stock pressure.
for those who dont know, he had a box custom made for him. so whats in it for a map could be a normal "attitude" style map or something totally one off. they can do wild stuff.
and yes, we found trying to diagnose a tuning issue on a buddies sled, got fuel pressure where you could see it and when the sled was acting up, fuel pressure was dropping. totally different issue, but if its not doing what its supposed to, get ready to chase your tail, seen some smart folks do it plenty!
What wastegate control were you running at the end?
I know that it is extra cost but for your first runs a A.F gauge is well worth the money.
There's no doubt it can be done, but you're gonna have to find out who's got them working and ask what there doing? Who's fuel controllers are working, the unit would at minimum need to see boost pressure, if not use an O2 sensor as well to add fuel? Ask one of the reputable builders. Does what you're using have extra injectors?
yeah i am thinking it might be worth getting one also
I am confused....you say here that it is worth getting an o2 sensor, and then you say you already have one? In the beginning you only had two injectors. At what point did you go to 4, and did you run it with 4? :face-icon-small-dis If we can keep it straight what you are running, how can you get any useful info?
the efi box i use adjusts fuel as boost comes on and and so on that way, using stock injectors, as soon as boost comes on it opens all 4 injectors,
