2008/9 IQR...What engine work is needed to make it a decent mountain engine?
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
I hope you guys can take a few minutes to help me out with some info.
I'm thinking of building a fun little 600 mid-length spring-boondocking/hucker sled...136" to 141"... I have a long track sled for other days.
Looking at the 2008/9 IQR 600 and wanted to find out what would need to be done to the engine to make it a mountain compatible engine.
I already have the chassis components lined up & on hand (front suspension, skis, shocks, tunnel, cooler, skid, track, driveshaft, seat cover, tank, handlebars/riser etc...)
I understand that the cluching needs to be done.
What is the differnce between a 2008 and a 2009 IQR... looks like the front suspension went to Holz in 2009... anything else.
I want to keep the bore STOCK on this (no big bore or bolt on 800CFi cyls)
Has anyone used any of the Altitude compensation systems on this motor in a high altitude situation (6-10,000 ft)
Pre-mix is OK for me.
Up to 30% Race mix is ok for me but I dont want to run full race gas unless it will make a big difference in how she runs.
What is the compression ratio in the 600 race?
Can I run the stock IQR pipe or is the powerband on that one not that great for mtn use?
Does anyone make a lightweight can for the 2008/09 IQ Racer that is NOT a stinger and uses the stock IQR pipe?
I'm looking for a something that is not so loud.
SLP says that their pipe would need to be modified to fit the 600 Race chassis... what would need to be done?
http://www.startinglineproducts.com/catalog.cfm?pageID=detail&catalogID=3&catID=19&productID=847
I
IQRIDR
1,257
538
Mountains, Alaska
I'm gonna have to agree. My 660 took a lot of abuse and made many a 700 or 800 struggle to keep up. Very durable and lasting big bore.
A
Nov 27, 2007
289
33
Grand Marais, MN
09 600r
You can run the 09 600R motor on 92 octane VERY safely at altitude. Just for some reference, I ran a WELL tuned Carls 660ves in an IQr chassis last year. My buddy had a 09 IQr 600 stocker that would trade pulls with me in a drag race. Strongest "pump gas" 600 I have seen to date. There is a noticeable difference in power (like sled lengths) between the 600 long stroke (08 and 09 race motor) and the 600HO. I would compare it to the difference between the 600HO and the 660HO. At sea level I was running a 600HO with a Dynoport pipe in my IQr and pulling an EPI gold with 10-62s to 8100. His 09 IQr600 was pulling an EPI gold with 10-64 bellybusters to 8300 no problem. That is a considerable power difference. My 660VES was running the same (gold/64g weight) clutching. Hope this makes sense, Craig
C
Clarke673
Somewhere between too dumb to quit and flat earth
Dec 2, 2007
3,138
483
83
Gardiner Montana
Just go EFI 800 now, you will thank me later. With the cost of a 660 kit you could buy a new 800 and sell your engine to pay for the pipes, high comp head, boyseen reeds, custom air box, and a good team clutch. Then after a year or two when sleding becomes against the law, and you need a turbo to get you away from the pine pigs, you are ready to go! :face-icon-small-coo
Thats what i am planning on doing....anyone want a 800 BOC VES kit for an IQR? $2500 with twin pipes, clutches, airbox,compleate wire harness, ETC. Even throw in a short warrantee.
