Thought I would go ahead and throw the list of whats on the rail. I know I missed afew things but this is the majority.
Dimensions:
Length: 16' 6"
Width: Front 88"
Width: Rear with paddle tires 100"
Width: Rear with transport tires 88"
Features:
* 1.5” 1020 DOM Frame done in Large Metal Flake midnight blue powder coat
* 1.5” Heavy Duty 4130 Chromoly Suspension done in powder coat chrome (Travel 18" Front / 20" Rear)
* King 2" Coilovers Front w/Billet Piggy Back and 2” triple bypass shocks
* King 2.5" Bypass Shocks rear w/Remote Reservoir and 2.5” triple bypass shocks
*425HP “Newstar” 3.6L DOHC all aluminum Cadillac V6 ( out of a CTS) with Turbonetics turbo. Capable of over 500HP with race gas.
* Bosch fuel Pump w/Billet Fuel pressure regulator, Filter (Fuel System on car is capable of supporting 700HP)
Stainless Steel Braided Fuel Lines
Billet Power steering, crank case (with filter), and coolant overflow reservoirs
* Mendola 2D Transmission that has every upgrade possible
* PBS Cable Shifter
* SACO Rack and Pinion
Power Steering (charlin Unit)
Jamar Pro X Disc Brakes and hubs Front and Rear (lifetime warranty against breaking)
CNC Dual Handle Cutting Brake
Jamar Pedals (Gas, Dual Resevior Brake and Clutch)
Aluminum 22 Gallon Gas Tank
Aluminum Hood, Side Panels, Roof, Center Console and WING TRUNK Done in Gloss Black with very slight blue flake powder coat
Autometer Gauges 2 5/8”, Oil Pressure, Water Temp, Turbo Boost, and Volts
Mac Tools 5” Tach with Shift light
Extreme HD U-joint Axles powder coated chrome, tougher than 300M axles and handle more HP and greater angles
Ron Davis Aluminum Radiator with dual fans
4, 6” Dick Cepek 100W Baja Laser lights on front end
4, 6” KB Customs HID lights mounted in custom light bar
Buggy Whip
PRP Seats (Front buckets / Rear bench), Seats 5 people comfortably
5 Dj Saftey Seat Belts
Engine and Transmission Skid Plate
Built in skid plates under driver and all passengers
Rhino Lined aluminum floor panels
3 each Billet grab handles and foot holds in rear seat area
Billet adjustable grab handle for front passenger
Billet side mirrors and 3 panel rear view mirror
Cooler bracket and included cooler
Billet handheld GPS Mount
35” Mickey Thompson Baja Claw tires mounted on Marsh Racing Beadlock Weels
33” Mickey Thompson Baja Pro dual use front tires mounted on Marsh Racing Beadlock Weels
Sand Tires Unlimited 16.50 Padla Trac paddle tires mounted on 5-star aluminum beadlock wheels
# Comes with transport tires (so you dont have to leave it on the expensive paddle tires and so it will fit in almost any trailer.)
Thought I would add a picture of the interior.
