<iframe width="560" height="315" src="https://www.youtube.com/embed/uaOHhbwH3NI" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
https://www.youtube.com/watch?v=GyI4WzbmxL0
At 2 minutes in talks about adjustable toe installation.
Remove bolt holding the brake cover …. 2018 does not have a bolt. It's a nut and the bolt is welded to the tunnel !!!
When installing with the existing bolt cant get 2 turns on the nut.
So how do I easily remove a WELDED bolt on the tunnel?
Bought a set of adjustable ones.
Went to BRP installation website !!!!
Is there a you tube video of the actual install for the adjustable?
One step is to tap bolt holes on the right footwell area. Want to make sure I am correct on the placement.
Thank you
I found this
Line them up, you do not need to drill out any welded bolt, the bolt and guy nut that comes out is the one the goes through the footwell to inside the clutch area, it is a 10 mm on both sides, and yes you will love them, every other sled has them, the bolts just screw in, there are plastic grommets hiding the holes, just back those out...its all in the video.
