looking for some advise,
I bought an 04 900 162 king cat with vforce reads, twin cpi pipes and can. Airbox is gutted. 400main jets.
Took it out a couple weeks ago for the the maiden voyage and got 5km down the trail and it died! I did not even open it up yet??? when it died I opened the hood and there was antifreeze all over. Started at around 3000feet -15c.
Towed it back, pulled the heads and found the mag side melted the rings into the piston, pto not to bad but some scaring.
opened the bottom end to check for any shavings and found the both mag and pto bearing retainers had somecracks(why do they use plastic retainers???
so now I've got a new crank, jugs, pistons etc. Going to put it together but i don't want it to happen again.
thanks
thanks
