<table width="100%" align="center" class="tborder forum-table" id="post4045232" style="table-layout: fixed;"><tbody><tr><td style="padding: 0px;"><table width="100%" class="profile-header" style="table-layout: fixed;"><tbody><tr><td class="profile-info" valign="top"><table width="100%"><tbody><tr><td class="pr-45">
LoudHandle <script type="text/javascript"> vbmenu_register("postmenu_4045232", true); </script>
<!--ADDED BY BRIAN FOR VB STATUS--> Currently:
Wrapping up my current builds, so I can start building my M-AXYS
<!--END ADDED BY BRIAN FOR VB STATUS-->
</td><td> Posts: 3,691
</td></tr></tbody></table></td></tr></tbody></table><!-- / user info --> </td></tr><tr><td class="alt1" id="td1"><!-- HEAVILY MODIFIED BY BRIAN FOR PAID/FREE THING --> <!-- Forum IDs are the list of restricted forums --> <!-- LOCKED FORUMS BRIAN locked_forums --> <!-- message, attachments, sig --> <!-- icon and title -->
Di-electric grease is Non-Conductive, therefore an Insulator!
<hr size="1"><!-- / icon and title --> <!-- message --> Quote:
<table width="100%" border="0" cellspacing="0" cellpadding="10"><tbody><tr><td class="alt2" style="border: 1px inset currentColor; border-image: none;"> Originally Posted by
bailer
I always just fill the female portion with a squeeze. I have used it on automotive and ag equip for 20yrs and never have had any trouble doing this and it has definitely solved and prevented many problems!
https://www.permatex.com/wp-content/.../tds/81150.pdf
I thought it prudent to throw this statement out there;
Using it as described above is okay on
some types of connectors that have enough
memory to retain their shape and push / scrape the grease out of the way where they actually are designed to contact.
If not? You essentially are floating the connector and making the issue you are attempting to fix worse. TPS connector being one prime example.
All connectors are not created equal and one should use some thought and good judgement as to where Di-electric grease is indeed suitable.
<!-- / message --> <!-- sig --> __________________
ALASKA
just 1 quick post that was easy to find. if you read
BULLSH** POLARIS (ELECTRIC RELAYS IN HARNESS GO BAD FROM WATER INTRUSION) (
1 2 3 ...
Last Page) its a good place to start but lots more info on that subject if you just go looking..... not to say ewanaburner is wong {pun intended
theirs only 1 wong
