didn't madmax weigh his full of fluids at 547? So you lost 11lbs with a full pipe set and a belt drive? Someone has a bad scale.
553 - 2016 LE 153.
I double checked the thread. He said the 17 was 6lbs lighter. So 547.
I probably should have put it on the scale when I got it but didn't. I did add the boards which add a little weight as well. Buddies Axys weighed 517 full of fluids stock on this scale and he has it at 498 ready to ride after mods. Believe it to be accurate.
Full Jaws pipe kit
Debating hood but the Helium is ugly, does look fair in green. The Mountain Fit has horrible fit problems and ices up. Any reviews on the Skinz hood? No way I will give up this track, the rest is minor. There are a few other things yet I can strip off. I'm fine with it, the sled can way out do what I can make it do anyways!
Can you elaborate on the iceing up you had with the Mt. Fit hood?
Thanks
