Belt deflection
H
Dec 7, 2009
44
7
Having a problem with my pdrive. When I torque it down it squeezes the belt too far and I can’t properly set my deflection. I have to run the belt about 1/4” lower in the secondary than it’s supposed to be or the sled creeps bad. Anyone know the fix for this? Sled is a 2017 850 165X3. Dynamo Joe clutch kit.
Dec 17, 2016
78
Northern Illinois
Can you post pictures of everything?
H
Dec 7, 2009
44
7
It’s on right. I’ve pulled it several times double checking. I’ll post some pics when I get home. It’s fine until I torque it. Then it’s like the dampener is going too far into the taper and I lose belt to sheave clearance.
kanedog
3,106
3,861
Can you post pics?
MKULTRA
493
349
quebec, canada
if the belt is too low it will creep forward, that's normal. I think you're looking at it backward
Sent from my LG-H873 using Tapatalk
H
Dec 7, 2009
44
7
It’s open all the way till I torque it down. I’ve checked pivot bolts ect to make sure nothing is hanging up on the spider after torquing it and everything is still free
