PROCLIMB Primary with Bearing
Deanearl
118
9
Was wondering how many have changed the primary clutch on their 2016 or 2017 Proclimbs to the newer primary clutch with the bearing? How much of a performance difference did you see and how difficult was the swap to get the alignment right? Also where can you get the best deal for the clutch and belt?
4,074
2,794
I put one on my 2014. Engagement is smoother and low end response is good. I can't say it's enough to warrant changing the clutch and belts if you already have a good working setup. Maybe it's more noticeable on a stock sled than my big bore? If you're due for a rebuild or replacement then it's worth upgrading.
Deanearl
118
9
Thanks Boondocker, that is kind of what I was wondering, as to if the performance difference was worth the money for the upgrade or not.
Allseasons
238
130
Rocky Mtn House AB
Personally, it was my favourite mod.
I had to add 2 spacers to align clutches, different size spacers, I don’t remember the thicknesses sorry.
ropinsno
50
9
Montana
I really liked mine, ended up going back to the stock alignment to get it to work right. There was a noticeable improvement, but really came alive with MDS weights.
