H
Want to pipe my 17 800 163 lie and looking for feedback on what everybody has . All riding at5-9000 ft. Not sure if a programmer is a benefit or not. What's everybody got?
I have the SLP stage 2 (pipe and can) on a 16 and 17, clean throttle response nice sound without being loud and some weight savings. I am not running a programmer but I am not sure about the 5000 ft. I think I would call SLP. We ride 7200 to 10500 with no problems and no hiccups at all.
We can mod your stock pipe here at T8RZ Porting and Performance. $250
Our local dealers demo 174 picked up a little over 400 rpm and holds it consistent when climbing in the deep.
The 155 demo picked up 450 rpm. Both sleds are ridden from 6000 to 10,000ft.
You could also achieve the correct RPM by clutching the sled right (weights) from the get go....
Ok, peaked my interest.. Does the character of the power change? And will it run safely at low elevation?We can mod your stock pipe here at T8RZ Porting and Performance. $250
Sent fra min S60 via Tapatalk
Started out with an slp pipe and can on my 16 switched it out for a Bikeman pipe, ssi can, pcfc. This year I'm adding the Bikeman y pipe and bully dog. That is if I don't decide to put a turbo it. :biggrin1: Main reason I switched pipes was because the slp pipes where cracking.
