Mtn cat conversion
dunatyk
932
331
Planning on doing a TKI belt drive/Mtn cat conversion to my 15 HCR. Questions I have are
1. Will the 15 drivers be ok or do I need to change them?2. Thinking about doing Mtn cat rails but I'm unsure of what components I can use out of my 15 skid...
3. Any advice on the install.
Thanks
F7arcticcat
75
I plan on doing my 14 this year as well. Did the TKI template come with instructions?
R
I don't know about the TKI. I went with C3 because they are here in Canada. There was no template just instructions. Pretty straight forward. About 3 hours to install. I have reverse also, not a problem like the 1100's. Silky smooth operation, big difference. I lost exactly 10lbs after I completed it.. Well the sled did not me.
boondocker97
4,074
2,794
Billings MT
I wasn't aware C3 made a drop and roll kit for existing non-MC sleds. Or are you saying you just put a C3 belt drive on without dropping the driveshaft?
Rinker
180
67
CO
Thanks
I was able to upload the instructions document in the PC thread. Check it out and it will give you an idea what needs to be done. The one thing I didn't mention was the rail tips need to be cut in order for the rails to clear the track. I just hacked off the plastic tips and it worked flawless last year.
Frostbite
4,738
721
Eastern Washington
Yes, I can say for sure that the TKI kit does work with the 2015 Jackshaft.
I can't say 100% for sure on the 2014 but, I am fairly confident it works with it as well.
You do have to drill and tap the end of the shaft of the new mount bolt for the upper pulley that comes with the kit. I had read and heard that was tough but, it went well for me without issues.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
14 jackshaft has a bolt from the factory, 15 uses clips and it needs to be drilled and tapped to be like the 14.
Mountain Cat
boondocker97
4,074
2,794
Billings MT
I upgraded to the 2015 jackshaft when I did the MTN cat upgrade to my 2014. Stronger shaft and it only cost $70. Tom has them on hand sometimes or you can get the kit from cat. My 2014 shaft bearing was going out too at 1600 miles so it really made sense to change it.
