new springs for slp 2
snowcannon
111
11
Shuswap, BC
I have a slp 2 kit on my 14 m8000 with about 1900 miles. Thinking it's time to replace the springs. A bunch of older threads mention h5 springs from speedwerx for the primary. I mainly ride 5-7k ft elevation. For that range a 120-320 primary was recommended along with stock 68g weights. I checked speedwerx's site but can't find that particular spring. What's the next closest spring I can/should use?
Also should I put a new spring in the secondary? Which one?
Lastly, what else should I do to the clutches maintenance-wise? I already plan to get go-rings from thunder.
All input is appreciated.
Sent from my SM-G950W using Tapatalk
Cat00
85
The closest would be the 120-310 I'm going to try that one this year with my mds weights
Last year I ran a 170-270 seemed to help some if I was going to do it again i would prob try a 170-250 or a 150-250
Frostbite
4,738
721
Eastern Washington
Yup, I thought the 120-340 would be the ticket but, the 120-310 H5 Speedwerx springs seems to work the best with my MDS weights. I also have an improved secondary spring that works quite a bit better but, I would have to do a search to see what it is.
There you go. I found the secondary spring thread and brought it back up to the top for you.
snowcannon
111
11
Shuswap, BC
Thanks for the responses guys. So based on those and the old thread mentioned by Frostbite, I will get a h5 120-310 for the primary and a h5 170-250 for the secondary.
snowcannon
111
11
Shuswap, BC
Frostbite, what rpm engagement do you get with your setup?
