2 stroke yz
Nov 13, 2008
205
34
So the big end rod bearing went on my yz250 last weekend (I also dune ride this bike). So I'm thinking its time for a Esr 345 or maybe the 325. Anyone run this motor? Looking for input on what pipe to run. Obviously I want it all, low mid and top lol. Really though I would like something that makes decent low and mid without killing the top end. Also anyone mess with the timing and see any gains? I'm hoping with the 345 kit to be in the upper 50s possible break the 60hp mark.
Nov 13, 2008
205
34
I think I got a couple. Rode it last year all stock right down to the pipe. Loved it. It don't have the 450 power but it feels so light and nimble in the tight trees.
wwillf01
2,790
616
Heber Ut
I feel the 2 stroke gives you a more exciting feeling with the light and nimble... Spring they are great... I felt it gives up the most in chute climbs and powder.... To me the rpm range is not long enough and you have to be way more select on gears... The lighter you are the less this happens... This was my experience on a ported head cut ktm 300 and cr500 .. again more exciting but less effective in the powder at the end of the day.. I run 10,000 feet and up.
Sent from my XT1585 using Tapatalk
jskattum606
923
400
Bozeman, MT
Same thing i felt on my modded KTM 300 last year. Definitely seems like its more important to have the gearing right for the type of riding, where the 4 stroke is a little more forgiving.
I think it is mostly due to the shorter RPM range of the 2.(7500RPM VS 12000RPM) Makes the gears feel farther apart
I felt i benefited from the 2 stroke in the deep snow because of the lighter weight. I had the E-start stripped from my bike and all though(IT WAS LIGHT)
In your case the 2 stroke has a disadvantage at that altitude. The 4 is a little more efficient at altitude. Especially when your starting at 10k. IMO snow bikes are WAY more fun when you can ride at 4-5k
byeatts
3,402
1,215
maybe in the past the 2 strokes weight was an advantage however the new Iron 2017 450sx on the digital scale was lighter than my 2016 300, the 450 was 223 lbs no fuel.
wwillf01
2,790
616
Heber Ut
Ya I still think it's the feel with the valve train and center of gravity.. That being said the 16 450sxf I road last year was so nimble it is what brought me to the darkside
Sent from my iPad using Tapatalk HD
jskattum606
923
400
Bozeman, MT
True, But Ktm is the only one. Everyone else is 20lbs heavier.
Also, you can strip 15 lbs off of the 300(estart, lights, battery, wiring harness) . Cant on the 450
portgrinder
407
Edmonton
stock a yz250 is around 47 at the front sprocket.
pipe gets you just under 50. I like the PC2
.025 slice off the head gets you another 2 all the way through the rpm range.
Porting by a guy that nows what he's doing will get you to 60.
from what i recall on mine, changing the timing didnt do anything.
boysen rad valve doesnt add any peak but adds alot of snap off the bottom line.
i wouldnt expect boring to do very much especially if you don't do the above. no personal experience though
Nov 13, 2008
205
34
The Esr kit is their own cylinder with a much better exhaust path. I can only presume that the intake tract is improved drastically also. Planning on the rad valve and also planning on measuring squish and getting that optimized. I would certainly think (or should I say hope) almost 100ccs over stock would make some difference??
wwillf01
2,790
616
Heber Ut
For sure will make a difference... A lot more grunt
Yetiman
40
29
53
Rumours are it's a smoker!
Someone gone a bit crazy! :juggle::juggle:
Tahoe54
171
62
I was debating doing this vs. doing a CR500AF conversion. It looked like a much easier and more cost effective project but I ultimately ended up going with the 500. Good luck, let us know how it turns out!
CATSLEDMAN1
2,630
1,207
Missoula, Montana
yz2
the yz 250 in the snow lacks some in the low mid but
add a boyseen rad vavle ........helps
Pick a pipe, I run an fmf gnarly
a 38 lectron will get you way better gas mileage and the throttle response feels like you added hp down low, helps plowingthrough early deep snow. pulls harder longer..........the stock KH carb on mine is an oddball anyway, best to park it, I run hot water around the bell for icing/ homemade thermostat.
gear it down a little, I am redoing by YZ250 kit right now, spare bike but spring fun, going to 2" 120
7 tooth 3.0 drivers'
18 jack shaft
16 18 in the chain case
it will gear it down alittle more, I rarely have it out on early season road rides, so jumpiing right up the hard snow hills I think this will be better
portgrinder
407
Edmonton
Pc2 made the most power when we had mine tied up to dyno in '09. 3-4 gain thought the whole curve if I remember correctly.
