Bought a syringe to fill the lines and the turbocharger, anything beside holding the oil injection linkage wide open to help prime the system? I planned to keep the oil tank cap off while idling. Any other tips or hints? Thanks.
if you put some into the turbo and pumped some into the lines, the few little air bubbles get pushed out very fast once you just go ride. And like I said, as long as the turbo itself was filled with oil your golden. Ball bearing turbo's need almost no oil to survive so if the center section is full it will be fine until the air is pushed out.
