Can't you just unhook the fuel controller and will know if it is the problem. Doesn't seem like it would be if it ran good at first
I was wondering the year difference as well being mine will go on a 2011 as well.
I would really like to see the throttle blades adjusted down, or for a quick and dirty check can you have sled running and place your hand or tape a board over the turbo air intake so see if you can get it to idle down steady with the intake air restricted? I just think it may be possible that when the sled idles higher the intake pressure rises a tad,thus causuing higher idle,thus causing more pressure in the intake tract,thus causing higher idle ect ect till the max limit of air through the closed butterfly is reached, about 3600 rpm.
we have to remember that we start at vacume in a non turbo engine, the motor "sees" this at idle, now with the turbo sitting there its still blowing air, so lets say if motor has na 14 inches of vacume at idle, then lets say 3 inches turboed...even tho there is no boost thats a huge change and a lot more air through the same .0025 butterfly opening, now if that enough to raise the idle to 3600 in our "loop" you are seeing much more air shoved through the same slot.
This also would make sence in the fact that you said when the engine first starts and you dont blip the throttle you have low idle, at the first rev idle climbes and stayes up..as turbo now spinning faster and your in 'the loop"
Just something to try if you could...give her a 1/2 turn closed, and see what happens, easy to turn backl if it dont work...good luck
like i said before on the dragon motors I rebuilt the adjustment was very sensitive, like 1/4 turn of less moving idle 500 rpms
I'll give it a try. I have nothing to loose.
If I put the sled back to stock for some testing purposes, Do I need to actually reinstall the airbox? Would a stock sled idle normal with no airbox installed?
It should idle normal with no airbox installed.
Got mine fixed today. Took it to the dealer to have my TPS checked and they found two issues. One was I had the oil pump plugged into the ECU harness and not the auxiliary harness. The other thing was my TPS was not set properly. The paint line was as it left the factory. Do there you go. Installer error (me)
AC PWR..is accesory power..and should be 12 volt DC...I worked on mine for a couple hours this evening. I took all the turbo stuff off the sled. I didn't see anything that was obviously wrong when I pulled it apart. My orings from tb boot to tb & tb to airbox were ripped slightly, but it looked like a fresh rip from me trying to get it back off. I don't think it happend from the install. I checked out my reeds, put the stock tb boot back on, mounted the tb's to that, no stock air box. I then rechecked my tps. I was using a different Fluke meter than I used the 1st time and the readings where off from where I just set it the other day. So I readjusted it with this meter. Put the stock pipe back on. Started the sled up, the fu***** thing still idles a 3000 rpms's!!!!wtf?
Everything from the turbo install is unplugged at this point. Couldn't believe it.
So I said screw it and just manually adjusted the idle screw back down to a normal idle. Seemed to work ok and my reverse still works.
After all that I didn't have the ambition to put the turbo stuff back on and try it again. Also, I couldn't find the correct size o-rings to replace my damaged ones at the local hardware store, so I really couldn't do it anyways. Hopefully I'll have new orings by Saturday and I can give er another try.
I know manually adjusting the idle isn't the proper answer but I don't know what happened. If it runs fine I guess who cares.
SSABMUD: You mentioned about he oil pump being plugged into the ECU harness. I have mine plugged into that same plug I think, the one above the clutch. Idon't see any other plug to plug it into???? The only other plug I'm seeing is one that is labeled AC PWR, but I need DC so that won't work.
