Note: this_feature_currently_may_not_be_available_in_some_browsers
Weight on battery?
This is the weight on my stock battery (14.9lbs) with the stock battery box. Here is the weight of the Lite Weight battery that BMP sells (2.35lbs). BMP also has a lite weight aluminum replacement battery box (2.90lbs together or 0.55lb buy itself) that also displaces heat compared to the stock steal box.
That is a 12lb weight savings! By the time you add a lightweight muffler you could save way more. 336CCA (270cca is stock). fast recharge (90% in just 6 minutes!) Lithium Ion, HD case and terminals, can be mounted in any position if needed. I used these batteries for the last few years with zero failures on my 800 Axys's. I even ran one in my wife 1100turbo sled. They claim 6-12 times more cycle life compared to lead acid batteries.
http://bikemanperformance.com/bmp-axys-lightweight-battery-kit-12-5lb-savings.html
