The season just started, why would you sell a brand new sled before the best part of the season is here?
The rear suspension on the XM looks hokey but flat out works. I want to hate it but it has the best ride of any stock sled. That said I put an evolution air setup in my 12 XP and it dropped 10lbs. On the Freeride it dropped an honest 12lbs. The XM needs better shocks on the front for sure. Double or triple rate springs and progressive adjustable damping. I'm going to try a set of EVOL Rs I got for my 12 XP up front. Thinking about putting the EVOL Air set up on the rear and getting rid of the T motion. I think the Flex edge Track does way more than the T motion.
Finally someone mentioned the clutches, well at least the primary has to go and the secondary should float. I am expecting the 6 arm clutch to get the dampener so it will go right on to the 2 strokes.
Just thinking, this might be an option for springless
Bingo. Doo doesn't really need to do anything next year besides continue to refine/lighten this chassis. Maybe new clutches.... :face-icon-small-win
You don't want the 6 arm clutch in anything IMO. It's a very expensive clutch to tune and play with. Each ramp in there is worth ~$50. If you were to rebuild, you're looking at somewhere around $400.
If I had a choice, I would bolt on a PB80. They work really well on the 1200's and can handle 250hp. Very easy to tune (weights/springs) and can handle 250hp.
Will be riding a 2014 on February 15, 2013 in McCall, ID. Should be fun, will report back after ride.
:yo:
Ski Doo factory demo ride. Check out the web site and see if any slots are open.
