I wouldn't put stock straps back in. I had same problem. I got a one piece plate from FTXMOTORSPORTS! Way stronger and also helps keep crankcase from twisting also.
funds are tight and I got a good deal on a pair from a buddy at a dealer.
Well I tackled her yesterday, and it went fairly smooth!
Let's dance..
Pretty much apart.
"Engine hoist" you safety dweebs can suck it.
Got 'em out and the new ones in without touching fuel lines, oil, clutch, y-pipe, throttle boddies, and half the electrical and coolant hoses.
Back together and fired up 2nd pull!
Thanks for all the help! And one thing I'd watch for next time, is when installing the PTO side make sure you don't pin your oil pump throttle cable plate thing under the strap. I got it back together, started, pull the throttle and it was jammed, couldn't believe it! Had to take the throttle bodies off (usually not a problem but with the new boots they're a bitch to get back on) and was luckily able to pull the plate back over with my finger, otherwise I would have been taking it all apart again to loosen that strap off :face-icon-small-sad
edit: Yes I realize my pipe is dented in. I'm having trouble finding anyone around here who can blow it out for me. How bad is it to run it like that?
