T
So I have a turbo nytro and I am afraid I may have damaged the engine. I tested the compression on the stock motor today to end the season. I warmed it up to about 140 to 150 degrees on the digital temp gauge and shut it down then tested it. I have about 2200 miles on the engine with about 600 boosted (hard miles and a little lean a couple times about 13:1 on AFR so I would not be surprised although I didn't really run it long at those levels).
I got around 135-145 PSI plus or minus a couple on all three cylinders. Then we added a little oil to the cylinders and it jumped to about 230 PSI across the board. Does this sound like rings?
It is weird to me that all three are low and all are the same. Maybe this is not out of the ordinary but with my experiences on two strokes it would be one cylinder or the other.
Im going to try another compression gauge to be sure its not my gauge. Any other thoughts? I dont get smoke or anything when it is running.
